0
0
Boyd's tank sending unit
Getting ready to order a 33 HR tank from Boyds.
Does anyone have a source for a sending unit that will work with the FF supplied fuel gauge? My preference is to use it instead of buying a second fuel gauge.
Originally Posted by
Scot
Just have to buy the gauge that matches Boyd's. That's what I did and several others did the same. It was easier to source the matching gauge rather than search for a sender to fit the tank.
dagall
I believe the one you want that matches the factory set up is the AutoMeter American Platinum Analog Gauge Number 1904. Summit is one source, but there are many others as well. http://www.summitracing.com/parts/atm-1904.
Dave,
Just want to verify that the ATM-1904 fuel gauge is the one that matches the Boyd Tank sender...can you comment before I place the order?
Don
DonC
Dave,
Don
Don, If you are using the factory gauge package, and your Boyd tank has the "0 ohms empty, 90 ohms full" sending unit, then this is the gauge you want. Dave
