I have not ordered the GTM kit yet, just purchased the donor today. However i am a long time reader of GTM forum posts, 4 years running.
Donor:
"2003 C5 CORVETTE CONVERTIBLE. THIS IS THE 50TH ANNIVERSARY EDITION. IT HAS 45000 KMS, THE CAR HAS EVERY OPTION AVAILABLE AND IS DONE IN THE ANNIVERSARY RED. RUNS PERFECTLY AND IS IN MINT SHAPE BUT HAS ONE SMALL PROBLEM IT IS BRANDED IRREPARABLE"
I also purchased the GTM Manual off the website so i could start the tear down.
I have also searched this website extensively but still have some unanswered questions
- The key is coded VATS, i assume this requires the BCM module but the instructions are not clear on if I need it or if there is a way to bypass it.
- Do I need the Corvette Flywheel?
- Do I need the Clutch assembly from the Porsche transaxel (or from the Corvette trans)?
- I want to end up with 5 point seat belts, is this http://www.northracecars.com/gtmparts.html the only option?
- I remember reading that someone had created wiring harness that were already completed (with the right connectors) Does anyone know if these are still available?
