Results 1 to 37 of 37
Thread: Oil pressure switch, What are you doing?
    818 Junkie... bstuke's Avatar
    Atlanta, GA
    I really like having an accurate gauge. On my Roadster I had a mechanical one with SS line to the gauge. It quickly exposed that I had pressure problems. A Milodon road race pan and pickup, along with a blueprinted Melling standard pump and proper non restrictive race oil filter quickly fixed that challenge. I never had a pressure problem again.
    What are you doing on your 818 to monitor the oil pressure and how is it working?
    Right now I have a stock pan and all, but still want instant feedback on what is going on with the oil pressure.
    Pictures and pro/con feedback is appreciated!
    Stuke
    818R For Sale!
    818R Sale Thread
    PADI Master Scuba Diver Trainer, PADI TecRec Gas Blender Instructor, Operations Manager - DNS Diving, Grand Cayman
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    Bob, did you want to add a gauge to your dash?
    Atlanta, GA
    Not sure, but wondered what others are doing. My initial thought is a panel with canbus, but those things are expensive!
    818R For Sale!
    818R Sale Thread
    Administrator
    Enterprise Alabama
    CAN bus dash only is $1100
    Kirkland, WA
    I added a pressure sensor to the galley and will run that into my data logger and run a virtual dash (could also run a stand-alone gauge)
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
    Atlanta, GA
    Thanks for the feedback Tony, what spot did you use, and did you just use an adapter to get to 1/4 NPT?
    Could one signal be wired to two inputs, say the ECU for logging and a dash gauge?
    818R For Sale!
    818R Sale Thread
    Freeport, ME
    Can we monitor oil pressure using one of those bluetooth ODB2 dongles???
    Just re-read my Cobb manual, says you can monitor anything in the ECU does that include oil pressure?
    Dan
    Administrator
    Enterprise Alabama
    Not since the Subaru only has an oil pressure switch instead of a true pressure sensor...
    Freeport, ME
    Gonna have to add a sensor and gauge...
    Dan
    Atlanta, GA
    Yep it is just an on off switch.
    It worries me as oil pressure is pretty important and there is no way to monitor it. I most likely will go with changing or adding a true pressure sensor, I can then wire it to the Megasquirt and it can monitor, log, shut down if needed, and send the info out the canbus to the display.
    If you are using the stock ECU, you will have to keep the switch if you can't turn it off completely, and run a seperate sensor to a gauge.
    Wayne can help steer you and get you the correct parts.
    818R For Sale!
    818R Sale Thread
    Administrator
    Enterprise Alabama
    There is not much room under the alternator so you may have to remote mount the sender
    Leesburg, VA
    Wayne, what are your thoughts on using one of those sandwich plates between the oil cooler and filter. Is it a good way of measuring pressure and temp? They seam cheap on ebay:
    http://www.ebay.com/itm/Oil-filter-s...3d9227&vxp=mtr
    Administrator
    Enterprise Alabama
    buy a quality billet one if you do buy one. You will probably not need an oil cooler unless you are running an 818R at the track. I have a customer that was at Sebring last weekend and was datalogging pre and post AWIC temps as well as oil temps. The highest oil temp he saw was 250°F at a track with lots of straights. You are not going to need a big oil cooler and it will need a thermostatic bypass. And then you can run a remote high flow race filter instead of the little Subaru one.
    Leesburg, VA
    I'm re-using the stock oil cooler (or heat exchanger) that comes with the EJ257. I agree it is probably not necessary for street driving but I'm keeping things stock in that area. I just wanted to know if one of those plate would be adequate for measuring oil pressure and temp (considering I'd like to retain the stock oil cooler and filter location). The one I posted is machined from billet aluminum and blue anodized, it's just not necessarily a name brand - all I'd be using it for is the two bungs for sensors. Thanks for the input.
    Kirkland, WA
    Quote Originally Posted by bstuke View Post
    I used a galley plug, the plug was under the intercooler (see the picture when you look at the galley plug from ProSport), I left the factory sensor in (under the alternator), I used a galley plug ( http://prosportgauges.com/subaru-oil-galley-plug.aspx )with 1/8 NPT then used a 18" grease gun hose with 1/8 NPT coupler on to a single wire pressure sensor (http://prosportgauges.com/performanc...re-sender.aspx ) so all-in-all like $35
    Tony Nadalin
    Administrator
    Enterprise Alabama
    I would use one of the other oil galley plugs for oil pressure and weld in a bung on the stock pan for oil temp then. Like he^ said 10 seconds before me but I'd use a braided hose instead
    Kirkland, WA
    I'm using a remote oil filter mount that has a 1/8 NPT on it for either pressure or temp, I will use it for oil temp (before it heads off to oil cooler). I also wanted to be able to get to the oil filter w/o having to remove the under the engine aluminum.
    Tony Nadalin
    Leesburg, VA
    That looks like a great option, thanks Tony & Wayne!
    Atlanta, GA
    Awesome feedback Tony, thanks. And it is something even I can't mess up...
    Cooler location is awesome too.
    818R For Sale!
    818R Sale Thread
    Is there an under engine aluminum panel supplied by FFR? I can't find one.
    Kirkland, WA
    Quote Originally Posted by tmoretta View Post
    If you bought the diffuser then you should have received the aluminum, I had to call as my diffuser did not come with the aluminum, seems there was an issue with the packaging of the diffuser not including the part number for the aluminum
    Tony Nadalin
    Clovis, Ca
    I used the OEM oil pressure light switch location as my oil pressure. I bought a plug with the correct thread that inserts into the block. It also had a 1/8 NPT hole milled in the center. Since it was close to the alternator, I bought a little 90 degree 1/8 NPT elbow and attached the oil pressure gauge to that. Fits perfectly and clears the Alt.
    For the oil temp- I used the rear port under turbo with appropriate VDO sender that actually was the same size M bolt and thread pitch- (easy peesy).
    Tmoretta- I had to call them to send me the under motor aluminum.
    Thanks- Chad
    Freeport, ME
    same here, called and they shipped it right out
    Dan
    I did not order the rear diffuser, only the front. I guess I am not eligible for the under engine aluminum. Would it be advantageous, aero wise, for me to order the aluminum panel? Also, for the large front panel under the radiator, what is general opinion on the pre-cut louvers? Should these be opened for extra cooling, will they vibrate or rattle off, should they be fixed closed? I am also noting a space/opening between the under rad. panel and the under battery panel - just under the steering rack. I am wondering if this opening will disrupt air flow beneath the front of the car. Anyone closing this off?
    East Hartford, Ct.
    What was the thread size into the block for the pressure sensor switch?
    Sgt.Gator's Avatar
    Bend, Oregon
    Quote Originally Posted by JB91710 View Post
    M18 x 1.5
    You can buy them with the 1/8" NPT on eBay, but I like the Prosport PSNUT the best. Or the Prosport PSNut Remote Kit. A bunch of vendors sell them, just Google PSNUT.
    Just the adaptor: https://www.rallysportdirect.com/par...hreaded-center
    Remote Kit: http://www.iagperformance.com/Prospo...p/psropkit.htm
    Here's a list of Subaru Thread Pitches. I have it taped to the wall in my shop for quick reference. : https://cobbtuning.zendesk.com/hc/en...re-Information
    Owner: Colonel Red Racing
    818R ICSCC SPM
    So then - you disconnect the oil pressure light switch and replace it with a pressure gauge switch? Does this cause the light on the dash to stay on? Is there a way to connect both sensors to the same (behind alternator) location?
    Administrator
    Enterprise Alabama
    You can run a T, get a dual pole sensor (switch and sensor combo) or leave the oil light wire disconnected which will not have the light on the dash.
    East Hartford, Ct.
    M18 x 1.5
    I'm referring to the oil pressure switch which is either 1/8"NPT or BSPT.
    Sgt.Gator's Avatar
    Bend, Oregon
    The Subaru oem adaptor is M18 x 1.5 with a 1/8" BSPT thread for the switch. Since no one else makes 1/8" BSPT sensors, you can use the PSNUT M18 x 1.5 with a 1/8" NPT thread to use aftermarket gauge sensors.
    818R ICSCC SPM
    East Hartford, Ct.
    I believe you're talking about an OEM Galley Plug location. I only have access to one on the front EZ30 engine. My alternator covers the rear one. I barely have access to the OEM switch location on the rear engine and the front one is accessible. The adapter in the first photo is NPT, I think. The OEM hole is BSPT, I think.
    What I'm having a hard time finding is M12 1.5 - 1/8"NPT for the Water temperature switch location and a M20 for the oil pan drain plug that will fit the thick VDO sensors. I need over 5/16" and most are smaller than 1/4".
    I understand that the EJ208 engine has three oil ports. I have found the one near the turbo (have adapted to add an oil temp. sensor), and the one behind the alternator (original location for the oil pressure sensor).
    Where is the third?
    Sgt.Gator's Avatar
    Bend, Oregon
    Where is the third?
    I think the EJ257 is the same as the 208, but not positive. Here's a pic that shows the ports. Note the one in the top front where the oem oil pressure switch is installed is not marked.
    The other three on the top of the block are very hard to use because the hard water pipe mostly or completely covers them. But they are there if you are creative.
    818R ICSCC SPM
    So it looks like any/all of the hex plugs right?
    Sgt.Gator's Avatar
    Bend, Oregon
    Almost. On the bottom of the block at least one is water/coolant.
    818R ICSCC SPM
    Yes, I love Technology
    aquillen's Avatar
    NW Indiana
    EZ30D - add pressure sender to existing pressure switch port
    I want to keep the pressure switch/oil warning light, but also have a pressure guage. Also keeping the stock oil/coolant heat exchanger. I decided to see if I could work with the space where the pressure switch mounts. One thing I haven't addressed yet is heat shielding from the exhaust header, but that will happen (this sender is big enough it will pick up plenty of exhaust heat).
    So far I'm not seeing why this shouldn't work just fine. The guage set is a "JDM Oil Pressure Guage" from eBay, and its supplied sender is a good sized lump. Sorry I didn't do a CAD, I'm faster with ms-paint so just tossed an image together with dimensions in case another EZ30D project wants to make one of these adapters. There is only a couple millimeters of lee-way in getting this to fit and I made three before I got the clearance to come out right.
    There may be an adapter out there for sale, but will it fit sight-unseen?
    As others mention - most guages (USA) are 1/8 NPT (27 pitch thread). The Subaru has 1/8 BSP (28 pitch thread - British). You have to drill/tap accordingly at each spot.
    Purchased:
    Ebay: The guage/sender $22.00
    McMaster-Carr: the 1/8 NPT x 1/8 BSP male-male adapter, $14.00 shipped.
    Amazon: Hanson 1911ZR Tap 1/8"-28Bsp Pipe". $7.00 shipped.
    Aluminum block from scrap bin.
  37. Thanks Wayne Presley thanked for this post
    Likes Wayne Presley liked this post
  38. #37
    Feb 2014
    If you guys are ever in a pinch for an adapter, we make a decent selection of M18 to NPT or PT, M20 to NPT or PT, NPT to NPT or PT, and a few others.
