![Boig Motorsports](https://thefactoryfiveforum.com/attachment.php?attachmentid=181712&d=1679150850)
04 Forester 2.5L engine?
Hello everyone,
I am looking at a 2004 Forester 2.5L engine this weekend. If I get the ECU (5 Speed), engine wiring harness, radiator, and stock headers, am I good to go? I have a complete set of parts from a donor 2003 WRX.
I have a 2003 WRX motor but want to go NA for now. I assume easier wiring and less complexity without the inter-cooler/turbo and stuff.
The transmission should bolt right up to the 2.5. Not sure if I need more of the wiring harness than just the engine part.
any help would be great!
Administrator
Do I need the gauge cluster? Not sure if things are compatible between 2003 WRX and 2004 Forrester
![FFMetal](https://thefactoryfiveforum.com/attachment.php?attachmentid=195371&d=1707243047)
