My iac valve on my 2002 impreza non turbo is a 2 wire not 6 wire
Lucky for me i got a hold of tec s which provided the computer tomy wayne harness and they
guided me thru a conversion to a 1992 vw golf iac valve which will work with the harness i bought from wayne
i almost have it wired and will update the results when i get it running , hopefully idling
kerry
door assembly tip: Make sure the front edge of the skin is inboard enough so the door will open all the way
if you look at the gap at the bottom of the door you should be able to stick your fingers in the gap
