Tony this is
great news, I can't wait to see how this works out for you. I love their endurance telemetry package so the pits can monitor the data in real time.
Until now I had dismissed RCP because they told me it wouldn't work with Pre 2008 Subaru SSM protocol. I even posted in their forum asking for updates because one other guy had made some mods to make it work for him using an Arduino:
ECU data from pre-canbus Subaru
Can you point me to the can bus bridge module? I see the adaptor cable on their website but not the module.
What I'd like to log off the Subaru ECU and into the RCP:
ECU_1 RPM RPM
ECU_2 SPEED Vehicle Speed
ECU_3 TPS Throttle Position Sensor
ECU_4 ECT Engine coolant temperature
ECU_5 TURBO_PRESS Turbo pressure
ECU_6 IN_VVT_R Right bank inlet timing
ECU_7 IN_VVT_L Left bank inlet timing
ECU_8 IGN_ADV Ignition advance
ECU_9 KNOCK_CORR Advances correction depending on detonation sensor
ECU_10 FUEL_LEV Fuel level
ECU_11 NEUTRAL Neutral sensor
ECU_12 CLUTCH Clutch disengaged signal
ECU_13 BRAKE Brake switch
ECU_14 ENG_LOAD Instant engine load
ECU_15 AIR_FLOW Air flow in the air pipes
I'm under the impression that the SSM protocol is too slow to log all these functions but at a minimum I want to log:
ECU_1 RPM RPM
Everything else I can get with aftermarket sensors.
