Thread: Rear Tire Size
    Nov 2016
    Petaluma, CA
    Rear Tire Size
    For the 289 FIA....will a 295/60-15 (Diameter =27" and Section Width = 12.8") work on the rear without modification?
    Senior Member Jim Doak's Avatar
    Midway, Utah
    I don't know if it'll fit but a 295/60-15 tire will be about 28.9" in diameter the way I figure it, not 27".
    Nov 2016
    Petaluma, CA
    Hello and thanks for the response. I took that diameter off of the tire spec sheet and did not calculate it myself. You may well be correct.
    Midway, Utah
    I think you'd have better chances with a 295/50-15 tire. It'll be about 26.6" tall. Plus I've seen them used on older FFR Cobras/Roadsters with IRS and they really look great. Still, I don't know if they'd fit on the FIA.
    A 275-60R15 is 27.9, and 28.9 is right for the 295.
    A 295-50 R15 is 26.6, so that might fit better.
    Elk Grove, NorCal
    I was down in Huntington Beach show a few months ago and there were two 289's there. I know one of them had 275/60 R15 in the rears and they fit and looked good. He had the knock off wheels.
    Huntsville, Al
    Quote Originally Posted by Vspeeds View Post
    The #1 car was the one I did for SEMA... it has 245/60/15 and 275/60/15. looks great and fits great
    Quote Originally Posted by Erik W. Treves View Post
    I was fortunate enough to see his car at the beginning of last year's Hot Rod Power Tour and it was truly amazing.
    Check Out Erik's Attached Thread For A Better Look:
    http://thefactoryfiveforum.com/showt...ighlight=mamba
    Nov 2016
    Petaluma, CA
    Erik, Those were Hoosier Quick Time D.O.T. tires, right?
  10. Thanks Trevor6 thanked for this post
