I installed the 31/16" sleeves in the front IRS mounting polyurethane bushings per the manual page 82. These sleeves appear to be too long. With the bolts torqued to 100ft lbs the sleeves cause a gap between the IRS mounts and the bushing. Shouldn’t theAttachment 76557 IRS mounts be tight against the Bushings or Is this normal?
I'm guessing your 31/16" sleeves are a typo, 13/16" maybe?
My kit with IRS should be here next month, hope they are correct.
Thanks for the heads up, I'll check mine.
Just finished installing the IRS in my Gen 3 Coupe a week or so ago. My sleeves in the front center section mounts were proud of the poly bushings similar to your pictures. Noticed it before assembly. I just ground them off to the proper length using my disk sander. I attributed it to tolerances including the poly bushings. Didn't occur to me I had the wrong parts but sounds like that might have been the case. It was a quick easy fix though.
Build 1: Mk3 Roadster #5125. Sold 11/08/2014. Build 2: Mk4 Roadster #7750. Sold 04/10/2017. Build Thread Build 3: Mk4 Roadster 20th Anniversary #8674. Sold 09/07/2020. Build Thread and Video. Build 4: Gen 3 Type 65 Coupe #59. Gen 3 Coyote. Legal 03/04/2020. Build Thread and Video Build 5: 35 Hot Rod Truck #138. LS3 and 4L65E auto. Rcvd 01/05/2021. Legal 04/20/2023. Build Thread. Sold 11/9/2023.
