Results 1 to 2 of 2
Thread: 818 Scrub radius?
    QC, Canada
    818 Scrub radius?
    Does anyone know the scrub radius of the OEM 818, with FFR recommended front wheel offset and tire size?
    Or at least, is it negative, dead 0 or positive?
    Tracked May 27/July 26, 2017
    Build Completed Winter 2021
    Sep 2015
    Hamersville, Ohio
    Frank iirc, the scrub radius would be the difference between the ball joint axes and the tire patch centerline. There are variables for every setup but you can calculate your own. Camber, caster, wheel width, offset, etc.
  3. Thanks Frank818 thanked for this post
