I need to replace my MSD distributor anyone have a recommendation
I would like to have one that doesn’t require a separate ignition box
Rick
Rick
Pertronix. They do have a series that uses a box, but the Flamethrower series does not.
http://www.pertronix.com/
you want a "HEI" type
Stay away from the flame thrower I have had no luck with those
The traveling Builder
717-773-5624
Ordinarily, I agree with Mark D (above), but in this case I will refer to my experience with Flamethrower...I have run this type of distributor in my last two engine builds and have had no issues with either. The first (in a Mustang with a 408C engine), I had lots of ignition issues (failures, really) until I replaced the distributor with a Pertronix unit. With FFR 8317 (my current build), I went directly to the Pertronix unit and have no issues. Of course, be sure that the distributor gear is compatible with your cam gear, no matter what you choose!
FFR MK4 #8317, 393 Cleveland, Lunati VooDoo solid roller, CHI 3V heads and intake, TKO 600, Std roadster seats, 8.8 3.55 diff, 17" Halibrand replica wheels, Ford "Magnetic Metallic", silver ghost stripe. (Sold 10/16/21)
Take a look at DUI products. More money, but I've had great luck with them and never seen anything negative posted about them.
Are we talking about MSD Model 83521?
Baghdad Bob
I have an msd 8595 for a 390fe
I had a Mallory distr. in my coupe ... ended up failing when the pin holding the cam gear/to distr. sheared. Replaced it with a stand-alone MSD and had no more problems. 422" Windsor motor.
