Got the Coyote engine and TKO600 installed yesterday. Started connecting the driveshaft today and looks like FFR didn't supply me the correct bolts to connect the driveshaft to the manual driveshaft adapter. Manual says to use the bolts that came with the driveshaft but they are M12x1.5 bolts which are too big. Looks like I need M10x1.5 bolts and I didn't see any in the parts I got. Will call FFR in the morning to get this straightened out.
Have a question on driveshaft alignment. I have the IRS rear end so the only adjustment as I see it using spacers under the transmission mount. Here's what I'm seeing:
I assume that I should go with setting the driveshaft at 0 degrees which puts me using a 0.55" spacer. Does this sound/look right?
