Results 1 to 3 of 3
Thread: Fuel Gauge Resistance
    Raleigh NC, OIB NC
    Am swapping SpeedHut classic gauges to replace the base FFR set. Can I tap into the harness at the dash or do I need to run the SpeedHut gauge wire from the tank?
    Kevin
    MKIV #8234
    No reason to run new wires if the existing ones are OK. The resistance range is in the sending unit itself. The sending units included in the kits typically calibrate to the Speedhut 16-158 ohms range.
    Raleigh NC, OIB NC
    Thank You
    Kevin
    MKIV #8234
