Hi Guys,
When I assembled the front brakes calipers on my MKIV complete kit, I applied some lithium grease to the two bracket rods-the ones which have the little rubber boots.
This was not a special grease, just white lithium grease with a melt temp of 450F. Do I need to use a special brake grease with higher melt temp?
I'm at a point that If I need to I can easily remove the calipers and apply a different grease if needed.
Martin
