Factory Five 33 Hot Rod. Finished in 2013/2014. Powder coated frame. Tilt column, 20" American racing rear wheels with Kuhmo ecsta spt 285-30-20 tires, 17" American racing front wheels with Kuhmo ecsta spt 245-40-17 on the front, 12.88 wilwood drilled and slotted rotors on the front, 12.19 wilwood drilled and slotted rotors on the rear. Split rear exhaust, 3 link suspension, Two tone paint, Leather seats, Red Line Racing 8 stack fuel injection system supplied by Wayne Pressley at Very Cool Parts, JBA titanium ceramic coated headers, All supply and return fuel lines are stainless steel braided with AN fittings, Fortes supplied a new Ford 8.8 rear end with 355 gears and a ford racing aluminum differential cover with girdle and a hydraulic clutch assembly, Ford Racing clutch and pressure plate, Stainless steel braided pvc system supplied by Pro Weld Performance parts, Rear cross over coolant kit by Modular Mustang, Aeroquip inline fuel filter and fuel pressure regulator, Boyds fuel tank and stealth fuel pump, Heat shield between the floor and mufflers, Entire interior has cool tec heat shielding mat installed, Kootenai custom parts supplied the seal plate for the fuel tank, wheel well sealing panels and the ss barrel bump steer kit. There is not a top but it was built to install the Factory Five rag top if so desired. Nothing but the best was used in the construction. Over $50,000.00 invested in parts and paint alone but the reserve is set much lower. Car is well sorted and ready for a new owner to enjoy. Just turn the key and go!!!! Motivated to sell.... reasonable offers considered.
Feel free to ask any questions. 203-994-5957 Only reason I am selling is I just have not had time to enjoy this car. Two kids involved in competitive sports. It is just collecting dust. Somebody should be enjoying this car!!!
