Results 1 to 12 of 12
Thread: Roxanne makes Her Entrance!!
    Trick Tool Maker, Super Moderator Hankl's Avatar
    Northern CA
    Most of you have been following the Carl Critz build, Carl doesn't post on the forum, as his day job keeps him way too busy, so I have the honor of
    bringing you the updates and pictures of his build. Just got these this morning, so enjoy, it's been a long build, but you'll agree that the results are
    OUTSTANDING!!
    If the exhaust on the Coupe looks familiar, it's what is now on the race cars, and some of the newer builds are using it also.
    Carl had contacted Burn's Stainless Steel, to produce a design Carl had come up with, Don Vaught came over to see it,
    and He had a copy made by a exhaust shop in the valley, and now Karen uses it on her race car, with very good results.
    If you look closely at the passengers widow frame, you'll see that it's broken up into two areas. The front part completely
    retracts, and the rear section is fixed, this allows the driver to use the drive-up at the local In-And-Out Burger!
    Just a "Beauty Shot" but it accents the flowing lines of the Coupe, adding 5 inches to the cockpit section, IMHO makes the lines flow even better.
    The lights are all HID, Carl will install the "Covers" later on, He's waiting for the new glass rear hatch to arrive.
    The Fog lights are also HID, and the fog light receptacle is also the induction ducting for the engine.
    Carl also has a Sunbeam Tiger, and he decided to carry over some of that into the Coupe. The Tiger has a Walnut Dash,
    as now also does the Coupe. Instrumentation is minimal, due to the "Stack" Instruments main display just in front of the
    steering wheel. The Stack system provides all of the necessary engine information, H2O Temp, Oil Temp, RPM, MPH, and has
    severals warning alerts that you can set for any value you want to be warned about. Really a nice clean area, for a very mean car!
    This is the business end of the power train. Carl with the help of Griggs Racing, came up with a Watts Torque link suspension.
    Needless to say, with 550 HP at the flywheel, this system will Hook-Up on demand, and provide excellent traction and stability at the rear.
    Still quite a few things to do, the rear disfusser is not installed, waiting for the glass rear hatch, little odds and ends yet to do, but all of the major work is done.
    Hank
    “If you didn’t have enough time to do it right the first time. How come you always have time to go back and do it again?” FFR1000186CP
    Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car.
    Horsepower is how fast you hit the wall and torque is how far you take the wall with you.
    Super Moderator
    Richmond, ca.
    Thanks for the update and new pics Hank. Good seeing you and RussF on Sat. to by the way.
    You have to see the car in person to really see just how much work went into this build, Carl changed just about every part.:-)
    It's really nice getting in and out of with the larger doors too!
    Fort Lauderdale Fl.
    Very very nice !
    FFR Daytona Type 65 Coupe
    67 427 Cobra
    57' Belair
    34 5 window coupe Ford
    2003 Mustang GT
    99' ZX9
    85 Goldwing
    Gorham, ME
    That is a stellar project. Congrats on getting to this point Carl. I'm still making pretzels with my brake lines!
    Great profiles! This looks like it belongs to an engineer. She's all business. I like it a lot, especially the suspension!!! WEK.
    Salt Lake City, UT
    Hank,
    Thanks for taking the time to post these photos and write up your summary. That is one exceptional Coupe!
    Member firechicken's Avatar
    Aug 2011
    Just.....WOW
    Incredible build ... thanks for posting, Hank.
    Milton,DE
    Wow! I really like the extra length, very well executed. Makes me want to build a Coupe...
    Olli
    Senior Member 289FIA_Cobra's Avatar
    Sunnyvale, CA
    Damn, I knew I should of built a Coupe! Great job.
    https://hhong43.wixsite.com/snkvnnm-build
    FFR #4883: 347CID|CompCam Magnum 286HR|Vic. Jr. heads|Hurricane Intake | Mighty Demon 650DP|IRS w/Torsen T2 & 3.55 | MSD ignition system | Mallory pump/filter/reg.|Forgestar CF5 18" w/245-45R18 & 295-35R18|Original I-Squared 1+1 System ☺ ☺☺
    Fresno, CA
    Very nice workmanship.
    Super Moderator vnmsss's Avatar
    California
    A-Mazing!!! Congratulations Carl on one outstanding build, and big thanks to Hank for posting all the photos and information along the way! Really love the eyebrow in the dash....May need to incorporate that into the next build. '.) Cheers!
    K
    #28 FFR Challenge Series
    #28 FFR Type-65 Coupe
    2011 Western Endurance Racing Championship
    2010 West Coast Champion
    Drive it.....Like you stole it!
