This will get the blood flowing!
Delivered: 6/17/2017
First Start: 12/30/2017
Completed: 12/7/2019
Legal: 1/30/2020
Wow!! Brutal...
Ok, got to note...
You can't put 1000hp on the ground *with street tires* any better than you can put 850hp to the ground *with street tires*.
Much less with xxxxlbs on the 1000hp Corvette, or xxxxlbs on the Demon.
Name a *street* tire (and turn off launch control + traction control).
And go try it at 500hp/500'lbs in a 2000-2300# *Cobra* replica...
You can do the same thing with 400/400 (maybe less).
