Results 1 to 5 of 5
Thread: windshield trim part number
    Edmonton Alberta
    I am looking for the windshield trim that goes on the body inside the glass. From the instructions it looks like there should be some trim, I either lost it or did not get it and at this point I will have to buy it locally. Anyone know what it is? I have the rubber trim that goes on the outside.
    thanks
    David W
    Mkll 4874 built in 2004
    Gorham, ME
    David,
    Flex line windshield auto glass universal molding flexible trim rubber 19mm FT UM1913BR
    3M 08682 Single step primer-30ml for the black border
    3M 08693 Glass urethane windshield adhesive cartridge-10.5 fl.oz.
    All available through Amazon.
    Hope that helps,
    Edmonton Alberta
    John, thanks I have those parts. What I need is the trim that goes on the body that it hides the edge that you would see from inside the car, it's like the bulb seal without the rubber
    David W
    Gorham, ME
    I used door edging available in any auto parts store.
    Then used some foam to hide the adhesive.
    https://www.ffcars.com/forums/21-ffr...indshield.html
  5. Thanks David Williamson thanked for this post
    Gorham, ME
