Results 1 to 10 of 10
Thread: Air dams
    Senior Member Packer fan's Avatar
    Janesville, WI
    Air dams
    Hi,
    My use is for around town and an occasional track day or auto cross.
    I am wondering if there are any air dams that are adjustable so I can use it around town and then lower it for the track. I like the look of them for every day use and then the effectiveness on the track. I saw the DWC splitter and may also put that on but it sounds like a air dam is more effective.
    Mk4 ordered 1/3/18, IRS, Coyote, T56 Magnum
    Colorado Springs
    I used the Dark Water air dam a while back. Easy to install, easy to adjust. Created a lot of down force, and allowed for higher cornering speeds. BUT, it also created a lot of drag, and decreased my lap times on the bigger tracks. I took it off, and I think it's still in my basement somewhere.
    .boB "Iron Man"
    www.RacingTheExocet.com
    Member Dewey McBride's Avatar
    Fairfield Ca
    I've been thinking about this too. Over 100mph the car isn't as stable. I saw on facebook a guy got an air dam or front spoiler and rear diffuser. He said it's night and day over 100mph.
    Colorado Springs
    Spoilers and splitters are much more efficient than dams. I have seen these Backdraft spoilers fitted to the FFR body. The results are said to be good. For a street car, this would be my first choice.
    https://www.iconicparts.com/front-spoiler.html
    .boB "Iron Man"
    Raleigh NC, OIB NC
    Nice looking. Wonder about driveways & speed bumps though.
    Kevin
    MKIV #8234
    I made one 10+ years ago using 1" square aluminum tubing and 3/8" thick conveyor belt rubber. The metal frame ends 2" or so above the rubber so that it can deflect if necessary which rarely happens.
    It uses 2 pins and 2 thumbscrews to attach and can be put on or removed in one minute. The rear struts are intentionally sacrificial so that it can hinge/fold under with a hard impact such as digging in during an off track excursion (thankfully untested!). Dig around with a search on the other forum and you should find a write up with some photos that I posted when I made it.
    I experienced much the same as Bob...it helps plant the front at triple digits but you can feel the additional drag at that speed.
    Jax Beach, FL
    For autocross, you need pretty big high angle spoilers / wings to be reasonably effective. They would be pretty silly looking on the street. Most autocross is a 2nd gear, less than 70mph event. Look at what they run at SCCA national Solo. It looks like they stole parts off of a sprint car. The track is different.
    Here is one of the fastest autocross cars that there is. They'd be sweet on a Cobra! LOL
    The track ones do look good. I am pretty much an old school look guy though.
    I was going to do a Track Night in America at Daytona tonight, but had work stuff get int the way. It is pouring down rain anyway and there is no way I would run a high speed track with nothing but concrete walls in the rain in a Cobra. Watching footage, 140 is common and I saw 160. I am sure some aero would be a big help on the high banks. I was honestly sweating a little thinking about signing up.
    What speed would you guys say these start getting light?
    100ish
    I don't think an air dam such as mine really adds downforce so much as it prevents some of the air from getting under the car and lifting it.
    "The I.E." SoCal
    One thing to remember is that ride height is going to play a big part in how/what the front air dam contacts. Kleiner runs his car pretty low as do I. I run mine 3-3.5" in the front and about 4" in the back. At that height my air dam was dragging on everything, it's no longer on the car.
    __________________________
    Janesville, WI
    Quote Originally Posted by Bob Cowan View Post
    I think this might be a good option along with lowering the car a bit more.
    Thanks all,
