I made a Plate to mount Electrical Components. i.e. Relays, Grounding Strip and possibly the Fuse Box?? I have seen photos of guys mounting it parallel to the Brake Box. Looking of ideas. I do have the New Generation Removable Dash. Also is there a Document that shows Fuse sizes for Systems> Ele Panel.jpg
Didn't your fuse box come with the fuses installed?
The wiring schematic that came with the car has the amperage of all the fuses.
That does not look like the RF fuse box that came with my Gen 1, not even close.... The 33 kit comes with a piece of aluminum to mount the RF fuse box on the side of the pedal box. some pics in post #61 https://thefactoryfiveforum.com/show...inishing/page2
As JimLev mentioned, the separate wiring instruction book that comes with the RF harness has wiring schematics in the middle of it and that shows the amperage of the fuses.
Gen 1 '33 Hot Rod #1104
It is an After Market Kit. American Autowire Power Plus 510008 Power Plus 20. I did find another diagram that showed Fuse ratings. Not the exact same box, but should be the same. I am mocking-up a mounting design. Ele Panel.jpgele1.jpg
ok, well if it helps, the RF box has the following fuse designations and ratings....
