I am working on front suspension this weekend and wanted to confirm that it is still best practice to trim about 1/8" off the rear upper adjustment sleeve on the front suspension, and also cut some off each threaded ends as well?
I am running power steering and my understanding is that this allows you to achieve desired alignment more easily.
Jason
MK4 Complete Kit #9673 | Ordered: 08/07/2019 | Pickup: 08/24/2019
Gen 2 Coyote, TKO600, IRS, Power Steering, 18" Halibrands, Kirkey Vintage Race Seats, Gas-N Headers and Pipes
Build Thread: https://thefactoryfiveforum.com/show...IRS-Build-9673
Yep, might as well. It's easier now than taking them apart later. The three I have helped with were limited to about +6.5 deg caster. That's OK but IMHO, minimal. I like 7.5-8.0. Also w/ normal production variation in the frame you usually max out one side, could get 1/2 deg more on the other side, but have to stop so both sides are the same.
Here's some pic's of mine if it helps. I cut those on a band saw. The one that is on the spindle knuckle I used a cordless cut-off saw.
If Brute Force doesn't work, you're not using enough of it. Basic Stuff: MK4 Complete Kit #8439, Wilwood's, 17" Halibrands. Extra Stuff: Stainless brake and fuel lines, Breeze cooling, Battery mount, SS Roll Bar. Old Fart Stuff: Heater, Seat Heaters, Footbox Fresh Air, Stereo, Keyless ignition, Power Steering, Hyd Clutch. Young & Dumb Stuff: 427w Dart, TKO600, 3 link Moser M9/Ford 9", 3.5:1, Eaton TruTrac Posi. Graduation Thread
