Thread: Plastic fuel tank cover
    Dec 2019
    Took delivery of my complete kit on 1-19-20 and am through the inventory. Couple of questions, perhaps for those that also received recently. I believe there are only two missing items, the plastic fuel tank cover and the power steering rack mounting hardware. Did you find the mounting hardware? Is the plastic tank cover still provided? Thanks
    Norton, MA USA earth
    I picked one up Tuesday and my cover was backordered as well. Havent looked at the steering yet.
    mike
    Senior Member Caddy Dad's Avatar
    Jun 2019
    Scaggsville MD
    Hi yahrt
    I just received my roadster kit on Jan 2. It too was missing the plastic tank cover and it's on my POL. No ETA yet on it. I also had a hard time finding the power steering rack mounting hardware. I was finally able to find it with help from FFR.
    FFR response:
    The mounting hardware consists of nuts and bolts and spacers from Box 1 and there should have been 4 new polyurethane bushings with your power steering rack. If not, please advise and will add to the MIK.
    I was able to find them in a bag inside another bag that contained the steering pillow block, support bearing and other pieces, etc. They're zinc plated ~4" bolts with nylock nuts. Some shims should be in there too.
    Good luck!
    Mk IV Roadster #9749, Kit received Jan 2, 2020, Blueprint SBF 347 TKO600 Holley Sniper EFI, Dual roll bars, IRS, 17" Halibrand, Nitto 555 G2 245, 315 Road legal Oct 20, 2020
    Nov 2019
    Charlotte, NC
    Your inventory list is your best friend when trying to locate fasteners. For the most part the bags are numbered good and that helps.
    I'm missing the cover as well.
    I'm curious about the question. You said your inventory was complete. Yet you're asking if the fuel tank cover is still provided. Every single nut, bolt, screw, washer, etc. is on the box-by-box inventory listings. Which you should have been using to check things off as you did the inventory. The tank cover is part number 14470, and should be on the fuel tank components box listing. It's either checked off as shipped or it's on the POL as a shortage. Shouldn't be any doubt about whether it supplied or not, unless it's missing from both sheets. Same explanation for the power steering hardware.
    x2 on the comment about the inventory listing being your best friend to find things. I put the sheets in a binder and use them throughout the build. As POL items show up, I put them in the box where they were originally supposed to be and mark off on the listings. The pages end up pretty dog-eared by the end of the build. But worth it. Also agree sometimes parts are not in the most logical places. But I still leave them were documented and confirmed by the inventory. That way I can find them when it's time. Staying organized, especially at first when there are a bunch of parts, and also especially for new builders, is key IMO.
    Dec 2019
    Yes, the inventory is complete and both of those parts are absent from both the inventory list and the POL list. That is why wondering if the fuel tank cover is still provided. Looks like they forgot the power steering mounting bushings and cover, no big deal, I'll get in touch with FF.
    Quote Originally Posted by yahrt View Post
    Got it. Yeah, that happens too. They've always worked with me to resolve.
