How is driving the hot rod in cold and rain
I am getting close to picking up a FFR hot rod here. I already have a MKII Cobra and put on 3-6k miles a year on it. But, I have noticed that rain is not fun with no roof. I have a friend who is selling his hot rod and I also have been looking around. I am close to making a hot rod purchase.
My big question is how are the hot rods with the roof on driving in cold or rain. I am going to assume that cold is not much of an issue if the car has a heater. I have driven my Cobra down into 20s before and been fine. It is rain that I am more worried about with the car being so light and having wide tires. I am going to assume that if you drive like an idiot, the car will punish you.
Originally Posted by
Brastic
I think that's a safe assumption.
Depends how it was built of course - the wiper system could range from non-existent to "basic" to very fancy dual wipers. Ditto the windows - I don't have any - and the fender situation. Driving in the rain without fenders will be "interesting".
Your wide grin will give you a warm glow though.
FFR33 #997 (Gen1 chassis, Gen2 body), license plate DRIVE IT says it all!
build thread
Seasoned Citizen
I wouldn't describe the hot rod as an "all weather" car. Not sure if any of the FFR cars are really weather tight but having a roof and windows has got to be an improvement over the open cockpit roadster you're used to.
33 Hot Rod Super Pro Drag Racer Build:
33 HR NHRA Cert Roll Cage Build
Not a hot rod just an old roadster but short wheelbase and wide tires are similar.
Wet is just wet. Most do that every day in the shower. You'll dry out, so will the car.
RainX, wipers maybe and a bailing bucket all help. Dry towels are good. Drain holes in the floor minimize standing water.
But tires make all the difference. Most of the summer tires are less than spectacular in the rain. Choose wisely.
Jim
Thank you all for the replies. There are some built 33s around me and I am going to go visit some of them.
Brastic
I did a show last summer about 50 miles away from the house. Fortunately, I had put the top on the day before so my wife would take a ride with me - apparently roadsters are not fun for those that have long hair. It was 104 degrees and not a cloud in the sky. Three hours into a 5 hour show, a few clouds began creeping in and things began darkening a bit. By the time I left, it was absolutely pouring & following me the entire way! There were a couple seepages around the side windows. I have my wiper in the back if I ever truly needed it, but I carry some individual packs of RainX wipes and to be honest with you, since the window is nearly vertical, that works great. I have Hagan Fattie mirrors...they are great during good weather & day driving, but not at all helpful at night - my vision doesn't help! To finish up, lots of wiping down when I got home with some extremely large & absorbent towels - to summarize, I don't recommend it & personally avoid it at almost all cost, but if caught in a pinch I think you'l be fine. I will say the car is extremely light, be very cautious on any wet or slick surface (sand, gravel, water, dew). I have had the front slide several times coming to complete stops at stop signs where there is just a little sand, trash or dirt. I also believe I have a little too much front brake right now. When I am at indoor shows, the fronts lock up & just slide! Working on the fix for that now! Take care and good luck!
Jamie
33' Hot Rod Coupe/Roadster (GEN 1), Fendered, Ford 302, 350hp, EFI, AOD, 4-Link, Double Adjustable Koni Coilovers, Split Rear Exhaust, Electric Power Steering, AC/Heat/Defrost, Moser 8.8"-3.55, Willwood Front/Rear Brakes, 18" x 8" Fronts/20" x 10" Rears, Ordered: 1.26.17, Arrived: 3.29.17, First Start: 7.2.18, Go Cart: 11.4.18 Paint/Body: 2.23.19, Back Home: 11.24.19, Completed: NEVER!; View More Pics @
https://starmobileone.com/
In the trunk of my Cobra, I have a weather proof car cover just in case and a bag of stuff for the passenger. The small bag that is loving known as the "wife kit" has gloves, small blanket, scarf for the neck and a scarf for the hair. I might have to make one for the hot rod if I get one.
I know where I'm located (Ontario, Canada near Toronto) the Hot Rod is going to be a fair weather car only, so heat is a must to extend my driving season. Thinking that heated seats and dash air would go along way if we get caught without the soft top and zip in windows up.
Seat heaters are easy to install and relatively inexpensive. The ones I bought last year don't appear to be available now, but there are many options available from all the usual sources. If you are going without a top you might consider spending a few more bucks and getting the waterproof version. Also look at what kind of controls you want - on/off or multi-level power.
Keith HR #894
I have heated seats in my Cobra. They are great and very easy to install. They are already on my shopping list.
Seasoned Citizen
build thread
From personal experience if you drive with the rain gage, the big one that rotates backwards, at about 100% the better portion of the rain goes over the cockpit and you don't get too wet. Big tires, big rooster tails.
Jim
