Every one of these cars (including mine) that I have seen autocrossed hard spewed fuel from the vent hose as soon as they were put in a long left hand turn with the appropriate level of enthusiasm.
The fix for that problem is the vent hose needs to come up about a foot toward one side of the car or the other (typically it comes up toward the passenger side with the Mustang tank in the roadster), then it needs to drain toward the opposite side of the car.
The object is to route the vent line toward one side of the car until it is near vertical, "U" toward the other side of the car then drain toward the other side.
That way when the fuel crowds to the vent side of the tank it just fills the vertical tube (to the "U") and has no further to go.
When the g-force subsides - it drains back into the tank.
Instead of just spewing out the vent line for the duration of the corner (or doughnut).
I've seen people try various check valve upgrades - but none of the (pricey) check valves close fast enough to prevent this effect in autocross, in my experience.
We always ended up rerouting the vent line as (roughly) pictured below (pictured looking at the back of the car).
That always cured the problem.
I'm not certain you have the same problem - but you might.
P.S. - Anyone who finds this problem is well advised to get a good road racing oil pan - complete with extra capacity, wings, baffles, trap doors - the works.
Because your oil is running up the side of the engine the same way your fuel is running up the vent line - except it's happening in both left + right hand corners.
Oil starvation follows - nothing good comes from that.
Yes - I had to replace bearings, polish the crank, and install a RR pan too - and considered myself lucky to figure it out before it became a catastrophic failure.
Good luck - words to the wise.
