Results 1 to 6 of 6
Thread: Marin - alignment specialist
    Aug 2020
    Marin, CA & Waverly, IA
    About to turn my roadsters engine on for the first time. Next up will be alignment! Anyone recommend a place in Marin county to get your roadster aligned?
    Oct 2014
    San Francisco Bay Area, CA
    If you have done your rough alignment, I wouldn't rush to getting the alignment done. The suspension settled quiet a bit between my first run around the block to the time I finished. I adjusted ride height couple of times. I put about 300 miles on her with my very rough alignment and it was totally fine.
    A bit far for you but I got mine done a couple of months ago at Roger Kraus Racing https://rogerkrausracing.com
    MKIV complete kit #8523, IRS, Coyote Engine, TKO 600, 3.55 rear end, PS, and a whole lot more! Graduated in May 2021.
    May 2020
    If you want to do a good self alignment I can loan you my toe plates and camber gauge, in San Rafael or Petaluma. Alternatively, there is a Porsche garage in San Rafael, S-Car-Go racing that is good. I am sure they can handle it even though they arent used to cars with the engine in the right place.
    Have you done or do you want to corner weight the car and adjust before alignment? I did a preliminary corner weight adjustment (i have scales) and moved it quite a bit to get the weight right which would change the alignment if done after.
    Aug 2020
    Would be great if I could borrow your toe plates and camber gauge. I plan to get the roadster cornered at Sonoma raceway but their earliest appointment is mid-July. So using your tool would be great to get a rough setup and sometime to break in the suspension.
    I’ll PM you to set up a pick up. Many thanks!
    North CT
    I just seen this video on alignment
    https://www.youtube.com/watch?v=IxnK1XE6ZAA
    Senior Member Mark K's Avatar
    Any decent tire shop should be able to do an alignment. Big-O did mine in El Dorado Hills.
    FFR9280RD MK4 base kit, 2004 Mach 1 donor, PS, PB, ABS, TC, CC, PATS, Summit heater, DIY wire diet, RT pedal/trunk/turn signal, FFR LCAs, FFR 3-link, 17x9 FR500s all around, Ford Magnetic Gray with custom Kandy Orange stripes (Ken's Custom Auto Body)
