Results 1 to 4 of 4
Thread: Wire Loom in door for Power Windows
    Mar 2018
    Hello, me again. So I have power windows and I was wondering what you all did to feed a loom through door opening at the hinges. Does it bind up when door opens and closes or should I use some type of door contactor? ALso, my body is at the paint shop and pretty much done. I have the rolling chassis now. I am thinking of pre wiring the power window motor for each door since the body is not on. Oh and I am using door poppers with no exterior door handles. So there will be a need to get power to the doors. What did you all use? Thank you
    Scott
    Jun 2020
    SoDak
    I used a door wiring loom conduit kit from Speedway Motors except I swapped the braided tubing for a thinner plastic tube to give it a little more flexibility. Worked great, of course I'm only running speaker wires into my door so I'm not sure how it would work on more than a couple wires.
    Link = https://www.speedwaymotors.com/Speed...-Kit,5349.html
    Jim
    Oct 2019
    Erin, Ontario CANADA
    Jim
    Jim,
    So am I right that the tubing is allowed to freely slide in the plastic-lined "eyelet" pieces? "Out of" the door when it's opened "into" the door when it's closed?
    I 'm asking because I'm guessing that means one needs to leave some slack in the wiring inside the door for flex/strain relief reasons...
    Earl
    Jun 2020
    SoDak
    Quote Originally Posted by narly1 View Post
    Jim,
    Earl
    Hey Earl,
    Yes, the tubing slides freely in the eyelet pieces as you described. Some slack in the wiring is definitely needed.
    Jim
  5. Thanks narly1 thanked for this post
