Results 1 to 21 of 21
Thread: Question for those of you with 351w and oval air cleaners.
    I'm just about ready for paint and as I have previously stated, I would like to go with the oval air cleaner and matching valve covers. If you are running a similar setup could you post the following information...
    Motor mounts used
    Intake manifold used
    Carb used
    Spacer size if applicable
    Filter element size
    Did you have to modify the body any to make it fit?
    Thanks for the info
    So. Bay (So. Calif.)
    It fit, but not much to spare. A 427w, (351w Dart block) with the standard FFR supplied Energy Suspensions motor mounts and trans mount, a 7/8 inch spacer for the trans mount, Edelbrock Performer RPM 7181, Dual Plane, Aluminum intake, Holley 750 CFM, 0-76750RD carburetor. There is a spacer for the air cleaner, but don't know exactly how high, 1/2 inch I think. It's to get the air cleaner off of the Summit Racing Sum 850312-1 distributor. I think the air cleaner is the standard 1 1/2 inch element, with the assembled air cleaner measuring 2.1 inches thick. These are the best pictures I got.
    Thanks boat..
    Only question is carb spacer. Are you running anything. My tristar performance 351w came with a carb spacer! Did you use one
    Quote Originally Posted by Usudno View Post
    At first I thought so, but it's just the carb flange. So, no. No carb spacer.
    Ohio
    I've got the same setup as boat737. No spacer under the carb but there is a spacer on top of the carb for the air cleaner to set on to gain clearance for the distributor. I could not gap my hood until I cut the hood scoop hole due to clearance issues. Air cleaner sets up in the scoop just barely.
    JRL16
    Member Toy4me's Avatar
    Voorhees NJ
    I have 351, now 408 with the standard Energy suspension mounts. Running an Edelbrock Victor jr intake and a Fast EZ EFI 2.0. On the base I had a shop mill off most of the flange that meets with the carb or throttle body. This dropped the air cleaner assembly about a half inch. I am running a slightly taller KN air cleaner for more airflow bit it clears the body with plenty of room. I'm running an MSD dist and it clears the plug wires with ease. I have pictures but PB is holding them ransome so I need to find another host for all my pictures.
    Generally the problem is actually the distributor cap/wires. The tall ones force the use of a spacer on top of the carb which raises the air cleaner.
    So a spacer, whether it be on the bottom or the top of the carb should not create much issue if my distributor is low enough. Correct?
    Right. And, if you have a choice, put a spacer under the carb for heat insulation vs on top.
    North CT
    Boat737 What type of transmission are you running.?
    Quote Originally Posted by chmhasy View Post
    TKO600 with a 7/8 inch spacer at the mount for drive line alignment.
    North CT
    Thanks I'm got the motor, transmission in and I have no idea how to align it to the rear axle . I'm running a 351w TKO 600 and Lincoln Mark VIII IRS axle
    I have no experience with IRS, but from reading the threads, I think you'll need a spacer for the trans mount. Look at EdwardB's 20th aniv. build. Post 255 I think. http://www.ffcars.com/forums/17-fact...y-build-9.html
    There are a few good threads on drive line alignment. I use the google search like "site:http://thefactoryfiveforum.com pinion angle" or "site:http://ffcars.com driveshaft alignment" or whatever search term you want.
    North CT
    Thanks boat737 your google search link resulted in a good read.
    My carb spacer is under the carb. I too have approximately 7/8" spacers for the tko500 that I am running.
    I had the same situation when I was building my Mk4 except I was building a "street" version with no hood scoop. I had found an old article in Car Craft magazine where they tested 20+ intake manifolds and one of the specs they mention was the height of the manifold. I ended up installing an Edelbrock single plane Torker manifold which was quite a bit shorter than the others. As it turns out, I did have to put a spacer under the carb so the oval air cleaner would clear the distributor cap but everything fit under the hood with about 1/2" clearance. Engine is a 410W with the poly engine mounts.
    Parker, TX
    I have been running the oval air cleaner with my 427w for a few years and I always wanted to get the bigger filter but I had no room at the rear where it goes under the body. I had to put in a spacer to get it over the distributor and that took up even more space.
    I finally decided to try a 5 degree carburetor wedge spacer.
    It worked so well I felt compelled to update this thread.
    I picked up over an inch in the front (over the distributor) and rear (under the body)
    It runs so much better with taller filter that whatever concerns I had about the 5 degrees are irrelevant.
    Also, I was worried that it would look funny but it actually looks better with its chin up a bit.
    CARBURETOR WEDGE PLATE, 5 DEGREE https://smile.amazon.com/dp/B000CON2...ing=UTF8&psc=1
    These pics are with the S&B 2.5" filter (w-2250-06) that would not fit before.
    I will likely go up the the 3" K&N next since there is so much room left.
  20. Likes Railroad liked this post
  21. #20
    Feb 2021
    Great solution. I also like the white treatment to the sheet metal. Painted? Powdercoated?
  22. #21
    Parker, TX
    Quote Originally Posted by CP82AERO View Post
    It is powder coated from Factory Five.
    It is one of the 20th Anniversary cars and the white panels was part of that package.
    https://www.factoryfive.com/whats-ne...ster-revealed/
