Thanks Thanks:  2
Thread: Tire / wheel help needed
    Oct 2023
    So…..
    Picking up my kit in a few weeks. Getting stuff ready.
    Doing a ‘33 hot Rod , full fenders, FFR IRS, sbc
    Looking at the Ridler 695 wheels.
    Front - 18 x 9 5.5” bs
    Rear - 20 x 10.5 6” bs
    Tires
    Nitto Invo Luxury
    Front - 275/35 18
    Rear - 285/25 20
    Will this work with a fendered body?
    Will I need any type of spacer?
    Will they work with the FFR brakes?
    I figure the “guru’s” on here would have some good advice.
    Just want to make sure they will fit
    Thank you for the help guys!
    Jun 2020
    SoDak
    I'm running full fenders and I used FFR's Bonneville rims w/ Micky Thompson tires
    Front = 245/40R18
    Rear = 305/35R20
    I have no issues with rubbing, but I did add a 2nd bump stop to the QA1 shocks in the rear because on really abrupt dips in the road the rear tires would rub the fenders slightly. Since adding the 2nd bump stop I have no more rubbing.
    Jim
  3. Thanks Guy G thanked for this post
    Jul 2020
    Spencer, MA
    What you want to get are tires that are no more than about 25.7 tire diameter per FFR specs for full fenders. Your choice for fronts seem too big, will rub on turns.The rears seem too small, will not fill wheel wells side to side. You'll have a hard time trying to inflate the rears on a 10.5" wide wheel. Mine are 295 on 10" wheels.
    Fronts - 17x8.5 245/40/17. Exactly 25.7 assembled diameter
    Rears - 18x10 295/40/18. 26" assembled diameter
    There is a guide in the PDF manual appendix if you downloaded it.
    Oct 2023
    Quote Originally Posted by Mastertech5 View Post
    Ok
    Thoroughly confused
    Based on tiresize.com,
    your rears are 27.3 diameter. 295/40/18 on 18x10 rims
    Your fronts are 24.7 diameter. 245/40/17 on 17x8.5 rims
    I don’t get the size differences?
    I believe what you’re telling me, but based on your assembled measurements you gave me, they are to large for the full fenders
    Now this is all based on info from tiresize.com.
    Do I not rely on their info?
    God I hate this part!
    I did go by the 25.7 that FFR recommends. And I thought the sizes I chose would have worked. They both come in at 25.6
    ( I miss the old days of G-60 tires for everything!)
    PS….found a 10” wheel from ridler for the rears!
    295/40/18 certainly computes to 27.3
    Yep I agree with your math
  7. Thanks Guy G thanked for this post
  8. #6
    Jul 2020
    Spencer, MA
    Well I measured them with a square and that's what I got. I don't know. I am using the lower suspension holes and have the rear ride height set at 6 inches. Plenty of room.
  9. #7
    Jun 2020
    SoDak
    Quote Originally Posted by Guy G View Post
    Ok
    Thoroughly confused
    Tires/Wheels and paint color were the two most stressful parts of my build.
    On Tire/Wheels after scratching my head for a couple months I finally said f**k-it and decided I liked the FFR Bonneville wheel/tire package enough where I was comfortable FFR knew enough where fit would not be an issue. Once they finally arrived, I was very happy with my decision because it was the look I was going for and the fit was dead on.
    Funny thing is on the 55 Ford F100 I finished building this year, there too, tire/wheels & color were my stress points.
    Jim
  10. Likes jwelch7818 liked this post
