Results 1 to 2 of 2
Thread: Cooling Fan Wiring
    Mar 2022
    Cooling Fan Wiring
    Hopefully someone can lead me in the right direction and I apologize if this topic has already been covered.
    I did not use the FFR electrical harness. I have everything wired checked and operating normally except the cooling fan which i have not connected yet. I cant seem to figure out how to wire the fan. The vintage air diagram has a hot lead (at least it appears to be a direct power lead to me as I do not have the RT fuse panel.) to the fan and then I guess the trinary switch supplies the ground when needed to close the circuit and turn on the fan. Ok that makes sense to me, however; the Coyote install manual has you connect the orange fan power wire and then a ground from the fan. If I supply a ground to the fan that already has a hot lead to it wont the fan just run all the time or is the hot lead somehow run through the AC and is not hot unless you turn the ac on and if that’s the case i am open to suggestions on how to wire it) I am sure there is an easy explanation that I am just too ignorant to figure out any assistance would be greatly appreciated
    Matt
    Replied to PM.
