Results 1 to 5 of 5
Thread: Throwout bearing install
    Member bigal0043's Avatar
    Jul 2023
    Update since my original post, kit arrived around middle of october, i am ready to install the motor transmission into my cobra. I have a 351c, and T5 transmission and a luk clutch kit. The clutch came with a throwout bearing, but i cannot for the life of me figure out how to use it on the fork i have. Is this just the wrong throwout bearing or am i being special? I attached a picture of what the throw out brearing and clutch fork look like.
    images.jpgthe-1979-1993-mustang-5-0-v8-heavy-duty-clutch-release-fork-throwout-bearing-ford-racing-perform.jpg
    Heart of Dixie, Alabama
    The 2 spring clips on the TO bearing should slide up on the 2 steps inside the big hole on the fork.
    O'Fallon, MO
    That looks like the wrong bearing. It shouldn't have a square on it or springs
    Senior Member weendoggy's Avatar
    Aptos, CA
    The bearing is installed with fork tang AND spring inside the "channel" of the bearing.
    I'm just a victim of a thousand physic wars!
    www.weendoggy.com/cobra.htm
    Jul 2023
    I ended up going to oreilleys and got a different clutch bearing that doesn’t have that flat plate on the back.
