Dyno Results for My Gen2 Coyote Roadster
Thought I'd post what I got during my tune done on a dyno. Not sure how this compares to what others have seen. Max HP was 402 at the wheels. Have seen numbers around 375 at the wheels for stock GTs.
Coyote Gen2, GasN headers with touring pipes, 91 octane tune, power steering.
MKIV #8414 - Complete Kit - Gen 2 Coyote - MT82 6 Speed - Wilwoods - Moser 3.55 Rear
Post Thanks / Like - 0 Thanks, 4 Likes
That's great. Do you mind sharing location and who did the tune? I would like to do the same for my car when complete
On a roll
I think your results are good. My Gen II tune resulted in 389 at the wheels, but I'm restricted by shorty headers and J-pipes. I believe Nuhale's tune resulted in about 411 at the wheels, but it's probably higher now that he swapped out his intake. I believe your 402 number is a good spot to be!
I can't find my dyno sheet from last year but I believe I'm around 435rwhp on a 93 tune.
Originally Posted by
Al_C
Build 1: MKIV #7275 Gen 2 Coyote TK600, IRS 3.55 2020 Covid
Build 2: Gen3 65 Coupe: Arrived June 2024. Gen 2 Coyote, T56, IRS 3.55 [/B]
Post Thanks / Like - 1 Thanks, 1 Likes
Al_C thanked for this post
Al_C liked this post
kirby
I found a local shop here is Salt Lake to run it. Their name is Premier Complete Auto Care and they have a tuner come in a few times a week. They are a performance shop. The name sounds like a lube and brake shop.
Thanks for sharing. That's higher elevation than I will be
25th Anniversary #9772
I did mine last friday it's a Gen3 with Tremec TKX and GASN touring pipes, 91 Octane, PS, PB, A/C, FFR equal length headers
On a roll
Tune and dyno prior to full blow driving. Gen 3 w TKO600, FFR Coyote ball headers and FFR pipes, 3:55 gears HP Tune we ended with 457HP at the wheels 400lbs of torque. Ran it to 7300 RPM.
Mk4 9735 complete kit delivered 11/29/19 Gen 3 Coyote, Tremec TKO 600, Moser 3.55 First start June 25, 2020 First Go Cart July 20, 2020
