4 way hazards wiring
Quick question. FFR instructions for how to hook up the 4-way hazards leave a bit to be desired. I searched this site and believe this is the correct way to hook up the RF wiring harness leads to the FFR provided switch. I believe I’ve used the correct switch… Please correct me if I’m wrong! Thanks!
You've got it correct.
MK IV Roadster #8631
