For the purposes of wheel selection what backspace do I need with the IRS rear axle?
I do have some straight axle / backspace /wheel well clearance data already and want to know if I can just use that.
Earl
Earl
Earl,
I went with a 4" backspace (apparently I fouled up the measurements), and it wasn't enough. I'm still mulling over what to do about that...
Other builders have recommended everything from 4.5" to 5.75". Based on my experience, I suggest 4.5" is optimum. You'll still have 1"+ clearance between the sidewall and the body, and 10" wheels will still fit inside the full fenders.
Keith HR #894
A bit more information:
I'm trying to figure out how a wheel with a 7.07" backspacing might work on my Speedstar with the IRS rear axle option.
I know that for a Speedstar with solid rear axle and a wheel with 5.88" backspacing the minimum clearance comes out to about 1".
I'm a little skeptical about using any fitment data from the standard 33HR given the two different body types.
If I had the track widths of the two axles to compare I'd have a much better estimate of the clearance.
Earl
Sorry I wasn't clear. Yes, I have the 2015 Mustang IRS in a Gen 1 Hot Rod.
Keith HR #894
Good info, but the unknown is if the Speedstar body is any wider or narrower at the rear.
I have since been told that the straight and IRS rear axle set-ups share the same track width. Just confirming that from a second source now.
So once I know that for sure and taking into consideration what a fellow Speedstar builder's results were using a straight axle, I'll know what backspacing I can use.
Earl
FFR confirms that the rear axle track widths are the same for both versions at 59.25".
Earl
Gen 1 '33 Hot Rod #1104
It's difficult for me to measure the track width right now. However, I did measure the distance between the body mounting points in the back: 41.75". Add twice the fiberglass thickness and ~0.2" to account for the typically used spacers (washers) and you get to the width of the body inside the wheel wells. How does that dimension compare to your Speedstar?
Keith HR #894
I'm not there yet. All I have to go by is how a known wheel backspacing /width combination worked out on a Speedstar built with a straight axle.
The 33HR and Speedstar both use the same frame, my concern is more about a potential difference in the body widths at the rear wheel well. So I'm leery about using 33HR backspacing / width data to pull the trigger.
Given the luxury of time I'd just wait until I was at the point where I could measure off the car but in this case I can't. The wheels that I really like may be discontinued soon and I don't want to miss out. LOL.
Earl
You can always go with a larger backspace and use wheel spacers if it is too much...
Keith HR #894
That's where I'm at Keith. The rear wheels I'm looking at will need about a 1" spacer to clear the body.
Earl
Perhaps I’m misunderstanding but there are a few different live axle widths available - I deliberately went for the widest rear to make wheel choice easier. So don’t use assume anyones live axle wheel choices will work for an IRS
