Results 1 to 15 of 15
Thread: Heater control valve
    Oct 2023
    Hey all!
    FFR supplied this monster heater control valve.
    I am running SBC with AC.
    Any creative location to put that monster?
    Senior Member EZ$'s Avatar
    Feb 2014
    San Ramon, CA
    Not sure about the new kits, but the Vintage Air heater that came with my kit had an electronic control valve that you could get from them. Only thing on the dash is a knob that controls the heater.
    Rick
    Placitas, NM
    I got the Vintage Air kit that FFR supplied with my kit, it’s pretty small.
    It’s got 4 knobs on the dash for heat and AC.
    Post a pic of what you’ve got.
    Sep 2022
    Huntington, IN
    Not the greatest but I put mine down low on the frame. The lower side panel will hide it yet it will still be accessible for repairs if needed.
  5. Likes FF33rod liked this post
    Oct 2023
    Jim
    Not concerned with the knob setup. It’s the 4 port valve itself!
    Oct 2023
    That’s kinda where I think mine is gonna go
    Oct 2023
    Quote Originally Posted by EZ$ View Post
    The valve itself is what I’m talking about. The knobs in the cockpit are fine
    Oct 2023
    Jim
    It’s the big bracket and the 4 port valve itself.
    Trying to keep under the hood kinda neat
  10. #9
    Oct 2023
    Did this today
    Should work
  11. #10
    Sep 2022
    Huntington, IN
    Quote Originally Posted by Guy G View Post
    Did this today
    Should work
    you done good
  12. #11
    Kingsland, TX
    You don't necessarily need a 4-port bypass style heater control valve unless you have some specific need like a DOHC 4.6 requires. You could use a smaller more compact 2-port valve:
  13. #12
    Senior Member Tooth's Avatar
    Nov 2020
    Groveland, MA
    I stuck mine up on the firewall above and behind the motor. Seemed like a logical spot to run the lines. On the roadster though.
    Mark IV Gen 3 Coyote
    Started 7/22.
  14. #13
    Oct 2023
    Quote Originally Posted by TxMike64 View Post
    Figured I’d use what came with it. Thought of a smaller one, but I managed to make it work
  15. #14
    Oct 2023
    Quote Originally Posted by Tooth View Post
    Thought of putting it there. Not really any room behind the motor on the 33
  16. #15
    Oct 2022
    FWIW, the Vintage Air Hot Rod heater I put in my 33 came with a two port valve. I put it under the dash attached directly to the heater core inlet.
