Results 1 to 4 of 4
Thread: Radiator Fan
    Senior Member Guardm16's Avatar
    Prescott, AZ
    Radiator Fan
    having trouble getting my radiator fan to come on.
    I am running the stock fan supplied by Factory Five. I am also using the Holley Sniper2 and Power Distribution Module (PDM). The PDM has a direct two wire connection for the fan.
    I highly recommend the PDM if you are installing the Sniper2, so easy! The programming of the Sniper lets you set the exact temp for the fan to turn on and turn off. The PDM has an LED to let you know the Fan circuit is "on".
    The PDM shows on, there is 12 volts at the connection to the fan. Only, no fan movement. I then tried to jump the fan from the battery directly to the fan, No fan.
    Any ideas?
    Senior Member lewma's Avatar
    Jan 2018
    San Diego, CA
    Bad fan ?
    Build 2: Gen3 Coupe Complete Kit #309 Ordered 1/25/21, Delivered 6/9/21, CA SB100 Registered 8/27/24 - BluePrint GM 427 LS T56, IRS, AC, Power Steering. Album Here
    Prescott, AZ
    Quote Originally Posted by lewma View Post
    Bad fan ?
    I also sent this same question to the Factory Five Tech.
    Apr 2024
    Maybe try just jumping 12v from the battery straight to the fan to test it out?
