Results 1 to 3 of 3
Thread: Radiator Fan not working
    Senior Member Guardm16's Avatar
    Prescott, AZ
    Radiator Fan
    having trouble getting my radiator fan to come on.
    I am running the stock fan supplied by Factory Five. I am also using the Holley Sniper2 and Power Distribution Module (PDM). The PDM has a direct two wire connection for the fan.
    I highly recommend the PDM if you are installing the Sniper2, so easy! The programming of the Sniper lets you set the exact temp for the fan to turn on and turn off. The PDM has an LED to let you know the Fan circuit is "on".
    The PDM shows on, there is 12 volts at the connection to the fan. Only, no fan movement. I then tried to jump the fan from the battery directly to the fan, No fan.
    Any ideas?
    Port Charlotte, FL
    Sounds like a bad fan to me. If you’ve run both power and ground from the battery and it doesn’t spin, definitely bad. If you just ran power and no ground to the fan from the battery, may be a ground problem.
    Henry
    Prescott, AZ
    Quote Originally Posted by 65 Cobra Dude View Post
    Henry
    I ran two alligator clip leads from the battery to the fan leads. not even a buzz from the fan.
