Thread: Just wondering if this body-swap would work??
    Senior Member MPTech's Avatar
    St. Louis, MO
    I've always wondered if another body could be used on a Coupe (or roadster). I think FFR's frames are amazing!
    Saw this beautiful body and immediately thought it deserved a frame worthy of a race care. It's close, wheelbase-wise: 1963 Corvette: 98" and FFR Coupe: is 96". I know the rollcage would probably not work, but I'm sure someone could figure that and the interior out. I'm just planting the seed.
    It's not for me, I'm very happy with my "Built, Not Bought" FFR MK4 Roadster F5R #7446, but I'm sure some Chevy guy itching to build a BBC with more talent than me could make this happen.
    Mar 2021
    SE WI Kettle Moraine
    I expect there is donation regret at US Body.
    jim
    A fabricator like my friend Gumby with enough talent to modify the FFR chassis to work would just start from scratch.
    Member otto halstead's Avatar
    When my MKII was totaled, I sold my frame to a guy in NY and he is putting a Jaguar Type D body on it. I don't know what kind of mods he had to make, but so far it is looking pretty good.
    Prescott, AZ
    The Roadster Shop makes very good chassis. Dave Kindig uses them as the basis for his CF1 semi-production version of the Gen 1 Corvette. If serious, RS will modify a production design for you. Unless you are a fabricator with a very well equipped shop, I think going to the RS makes more sense. However, you could never put together a Corvette replica for the price point of a Factory Five. But if you have to have one, the components are out there.
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    RS will even make fully custom frames, but they're spendy. For a time I was contemplating putting a Mercedes 190SL (W121) body on an RS chassis, and had spoken to them about it. You basically send them the body and they 3D scan it and build a fully custom frame for it.
    Mar 2021
    I have an Avanti project that replaces the (1953 design) Studebaker chassis with a C4 Corvette chassis. I stripped the C4 and did a FEA of frame stiffness. The result is an equivalent truss frame design (below the floor pan) with C4 front crossmember and rear frame stub for stock Corvette suspension at 109in wheelbase. LS engine and six speed.
    jim
