Results 1 to 10 of 10
Thread: Coupe stripe layout
    Dec 2021
    Coupe stripe layout
    Is there a guide to laying out the stripes on the coupe?
    I see that the roadster usually has 7" with 1" gap... some are tapered, some straight.
    I really like the stripes on the display coupe and was wondering if the dimensions are anywhere to be found?
    Salt Lake City, UT
    Post #10 has the dimensions I used on my Gen 2 Type 65. I can try to find some better pictures if that would help.
    https://thefactoryfiveforum.com/show...nd-Isocyanates
    Dec 2021
    Thanks. Looks great.
    Junior Member 8secDuster's Avatar
    Jul 2024
    Jacob,
    Did you use a Round Paint Mask to lay out the hood Roundel?
    Salt Lake City, UT
    I'm sorry for the slow response; the last few days have been nonstop motion.
    I didn't use a commercial product for the roundel. I made a 19.5" circle out of heavy paper and went around it with 1/4" plastic stripe tape, which gave me 20." From there I filled in the roundel with masking paper and masking tape. If I had known of a commercial product to make the roundel, I would have used it. Taping the roundel was tedious and time-consuming. Anything to make the process faster and easier would have been welcomed.
    To make the paper circle I took a piece of flat aluminum and drilled two holes in it 9 3/4" apart. Put it on the paper with an awl in one hole and a pencil in the other, and spin it around to make a big circle.
    Jul 2024
    No worries.
    What did you use as a distance between the stripes and the roundel?
    Salt Lake City, UT
    That distance is 1/4." I ran a second circle of 1/4" plastic stripe tape (my term for what I think is a 3M product) around the roundel and used that second circle to set the 1/4" gap.
    I'm pretty sure the distance between the stripes is 1.25," rather than the typical 1." I would measure it but the car is a long way away. I can ask someone to measure it if you want that exact dimension.
    Jul 2024
    I thought that was what I read, just wanted to make sure. No worries with between the stripe measurements.
    Thanks for the response.
    Regarding roundels/meatballs: Get with your local sign shop and have them make your circles with their CNC vinyl cutter using masking vinyl. The masking vinyl is more flexible and has a different adhesive which will easily to lift off but still give a sharp, clean edge.
    Division between the roundel and stripe is 1/4" on this one.
  10. Likes Skuzzy liked this post
  11. #10
    Jul 2024
    Thanks Jeff, appreciate that. What color is that Roadster?
