Thanks Thanks:  3
Likes Likes:  6
Results 1 to 14 of 14
Thread: Stealing yet another one of AARon's great ideas!
    Senior Member Rebostar's Avatar
    Jan 2024
    After useing AARons great footbox cooling idea I swiped another one of his mods! So let me give kudo's to AARon for his You Tube vids on his build. He explained how he made is own scoop and how he installed it. I did not want the FFR screwed/rivited on plastic scoop. I liked the MK2 & 3 scoops built into the hood. So I bought a fiberglass scoop from Tony Branda. Its a very close match and I can fiberglass it in, which you can not do with the plasic one. Seeing AARon's install I was sold.
    The first was to lay out on the hood where the air cleaner is in relation to the hood, top and bottom. Then after finding and marking the centerline, I laid out the placement for the scoop. Then it was just cut out the inner line then use a router to remove the top section. After sanding everything smooth I used the NAPA fiberglass short strand filler to seal the upper and lower skins togeather. This will dry overnight. Then I'll bond the scoop on using the same fibergalss filler and screw it down while it dries overnight. After that I'll fair everything in with the Rage Gold.
  2. Likes Railroad liked this post
    Jan 2024
    After drying overnight I sanded everything down again and bonded on the scoop with the NAPA fiberglass short strand filler. I pre drilled 1/8" holes before bonding and screwed in #8 PK screws every 3". This will dry over night.
  4. Likes D Stand liked this post
  5. #3
    Jan 2024
    I put the first coat of Rage Gold on last night. This moring I sanded that down and put on a secont layer. Tomorrow I'll sand that down and put a final finish layer of 3M Platinum. And that should do it.
  6. Likes Mike.Bray liked this post
  7. #4
    Aug 2012
    Grand Rapids, MI
    Nice work. Looks great.
    Jim
  8. Thanks Rebostar thanked for this post
  9. #5
    Jan 2024
    I put on the 3M Platinum around the outside seam last night. This morning I sanded that down. On the bottom side of the scoop it has the same rough finish as the inside of the body. this will show when the hood is open so I sanded that down and put a coat of 3M on it. Tomorrow I'll sand it down and do one more final coat of 3M. Then its on to primer.
  10. #6
    Jan 2024
    Final Pic of the scoop install. Only minor paint prep left to do.
  11. Likes Railroad liked this post
  12. #7
    Feb 2022
    Flower Mound, TX
    Looks great. It's what I want to do with my hood scoop when the time comes. Nice work.
  13. Thanks Rebostar thanked for this post
  14. #8
    May 2023
    Frisco, TX
    Nice work! I actually just posted my progress from today on my build thread for this part of my project. I hate the riveted look too. But I used a Shell Valley fiberglass scoop that’s a little shorter in length but taller in height.
    MKIV Complete Kit # 207585
    Ordered 8/19/2023. Completion date 11/11/23. Delivery date 11/27/23
    Build Thread: http://https://thefactoryfiveforum.c...577#post535577
  15. #9
    May 2023
    Frisco, TX
    Quote Originally Posted by OB6 View Post
    I thought you were going for a street-version with no scoop and no side pipes.
  16. #10
    Jul 2021
    York, Maine
    Hey I just saw this post. Thanks for the shout out. Here's a picture of my scoop, with a slightly updated paint scheme. I painted the metal screening a contrasting color-- pretty happy with the results. Also may make my car go a little faster
    Picked up kit 9/6/22. Complete Roadster Kit, IRS, 18" wheels, Forte 302, T5. First build. No auto mechanical experience and beyond excited to learn. Loaded with "Empty Nester" time and energy. Link to my build videos: https://www.youtube.com/channel/UCgX...uCWGcelzGecm1Q
  17. Likes Rebostar liked this post
  18. #11
    May 2023
    Frisco, TX
    Man… people have told me I’m slightly insane for the changes I’ve made to my build. But, I followed your build, and you’re certifiably insane.
    Well done!
  19. Thanks Rebostar thanked for this post
  20. #12
    Jul 2021
    York, Maine
    Quote Originally Posted by Mbufford View Post
    Well done!
    I wear the "certifiable" badge proudly.
    I'm famous amongst my friends and family for adding difficulty to an already difficult project...
  21. Likes Rebostar liked this post
  22. #13
    May 2023
    Frisco, TX
    Quote Originally Posted by AA-ron View Post
    Same here!
  23. #14
    Jan 2024
    Well, I've been told by an ex-boss that I could complicate a corn flake! He was spot on! 45 years of having the FAA tell me what I could and could not do, now its like Burger King, I get it my way.....even when it ends up like soggy cornflakes!
