Likes Likes:  6
Results 1 to 9 of 9
Thread: The Pyramid of Intellect
    Dec 2021
    Flower Mound TX
  2. Likes MB750, Rebostar, Chainsaw liked this post
    Senior Member JJK's Avatar
    Jul 2022
    DFW Texas
    and I was that close
    Will get smaller & smaller as we die off. Then it will be what's a carburetor?
    Kevin
    MKIV #8234
    Senior Member MB750's Avatar
    Feb 2022
    Tampa, FL
    I'm gonna put that on a couple motorcycle forums I'm part of.
    Matt
    My build thread here
    And above that are people who can set points and dwell
  7. Likes Rebostar, Ian G, BRRT liked this post
  8. #6
    I have farmers pliers, and a piece of baling wire. I should be up there someplace.
  9. #7
    Senior Member Rebostar's Avatar
    Jan 2024
    Hot dam Maynerd, I's a gienus!
  10. #8
    Jan 2024
    I once drove from Denver to Western Massachucetts in an Opel Kadet with a match book (extra credit if you know what that is) keeping the points from grounding out against the distributor wall. This proves that point gap setting and dwell angles are approximate values! And yes I have and use my FORD wrench regularly!
  11. #9
    Jan 2024
    I can take a set of points apart and file them and make them work, can adjust timing with a regular timing light, can adjust brake shoes on drum brake set up, can adjust carbs on cars and motorcycles, can repair the end of a clutch cable with a small torch and a drill, can actually weld with a torch and a clothes hanger like my granddad taught me, etc etc etc
