Results 1 to 1 of 1
Thread: FF MK 3.1 non donor car.
    Oct 2019
    ar
    Factory Five roadster series Mark 3.1.
    Dual Chrome roll bars
    Custom made fuel tank holds about 22 gallons
    Carbon fiber dashboard
    Hidden trunk hinges
    Drivetrain
    Levy Racing stage 5 408ci Windsor. 540 HP/550 ft/lbs
    Holley Sniper fuel injection
    MSD 6 Ignition system
    Headers with Gas n pipes and heat shields
    Canton road race 8 qt pan
    Levy racing Super Alloy T5 with mid shift (capable of 800 ft/lbs)
    Levy racing chrome Molly drive shaft
    Quick Time safety bellhousing
    Spec stage 2.5 clutch
    Mike Forte Hyd clutch setup
    2004 Ford SVT Cobra IRS center section with 3.55 gears Carbon fiber Trac Loc clutch pack
    Billit Flow IRS differential brace
    Drive shaft Level 5 CV axles capable of 1000 HP
    NT05 Nitto tires 315-35-17 rears 255 40 17 fronts
    Wheels Halibrand Replica Knock off
    Engine cooling
    Ron Davis High HP radiator made for FFR
    Dual Spal cooling fan setup
    Custom made upper and lower SS hoses
    Cobra Earl T stat housing
    Suspension and steering
    Levy Racing Koni double adjustable shocks F&R
    Levy Racing upper and lower front control arms fully adjustable
    Rear suspension all Heim jointed pivot points
    PS setup
    Forte’s bump steer kit
    Brakes
    Levy Racing Wilwood Superlite 6 Piston 13” front setup
    Levy Racing Wilwood 4 piston 12” rear setup
    Wilwood triple MC brake/clutch pedal assembly
    CNC Triple reservoirs
    Lokar mechanical hand brake
    Electrical
    Infinity Multiplex wiring system
    All weatherpack terminals
    Polished 1 wire alternator with 120 amp breaker
    Dashboard/cockpit
    Auto meter gauges
    Toggle switches with push button start
    5 point racing harness
    Kirkey 16 inch seats with covers and seat heaters that work!
    Misc stuff
    Wind wings and sun visors
    Keyed master cutoff switch in trunk
    Tangent hidden roll bar mounts
    Tangent Driving light kit
    FFR metal battery box sunk and hidden in trunk
    Carpeted trunk area
    FFR extended firewall
    Cobra earls powered foot box vents
    Breeze Automotive rear view mirrors
    Mechanical throttle setup
    All nuts and bolts are SS fasteners with Button heads used where (beauty) was needed
    $63,000
    I M. for pictures.
    Located in The DC Suburbs.
    3IMG_0601.JPEGIMG_0602.JPEGIMG_0605.JPEGIMG_0601.JPEGIMG_0602.JPEGIMG_0605.JPEGIMG_0600.JPEG
  2. Likes Bart Carter liked this post
