Thanks Thanks:  2
Likes Likes:  2
Results 1 to 5 of 5
Thread: Autometer Speedometer to TKO Wiring Question
    Member TTimmy's Avatar
    Sep 2021
    Emmaus, PA
    Hi folks,
    Do I need to wire up both the green (signal) and grey (return) wire to my Autometer gauge?
    The prior owner had trimmed back the grey/return wire and the wiring diagram seems to indicate that it is NOT needed. I have TKX if that matters. Obviously, I would like to confirm this before I button everything up!
    Thanks!
    TTIMMY
    Jun 2023
    Texas Hill Country
    TTimmy,
    I found the gray wire needs to be grounded. See pasted text below from post #51 in my build thread:
    Speedometer Debug, Clutch &Gears
    -2 wires in RF harness and connector to TKX electrical speed sending unit.
    -Obvious RF green wire labeled “speedometer signal” goes to speedometer “sig” input. -Not obvious what to do with gray wire labeled “EFI-speedometer signal return”. With it left disconnected (I have a carb’s engine) the speedometer doesn’t move (after its initialization) with driveshaft spinning. After reviewing Forum posts —The gray wire must be grounded.
    Now the speedometer works although I haven’t calibrated yet.
    BUDFIVE
    Complete kit order 8/28/2023
    347 Ford Dyno 10/12/2023
    Kit Delivery 11/28/2023
    First Start 7/4/2024
    Go Cart 8/31/2024
  3. Thanks TTimmy thanked for this post
    Likes TTimmy liked this post
    Senior Member Nigel Allen's Avatar
    South Australia
    I would be inclined to connect the gray wire from the speed sensing unit only to the ground wire that enters the speedometer. This prevents interference from stray ground currents getting into the speed signal circuit.
    Hope this makes sense.
    Nige
    Gen1 Coyote / TKO600 / IRS
  5. Thanks TTimmy thanked for this post
  6. #4
    Jun 2022
    hmm, I just noticed my speedometer had power but wasn't changing while go carting. I guess I know why now.
    MKIV Roadster - Complete Kit - Delivery 10/12/23
    Oct 2020
    Albany, NY
    Yup, grey wire goes to ground.
    Build Thread #1 https://thefactoryfiveforum.com/show...been-delivered
    Build 2 MK4 #11061- Delivered 08/24/24
    Build Thread #2 https://thefactoryfiveforum.com/show...006#post562006
