Thread: NRG steering wheel plastic jig
    Feb 2018
    I am in need of the plastic jig for NRG quick disconnect. I must of gained some weight over the years and getting into the cobra is starting to look queered! Thanks
    Mark III 347/435 hp TKO 3.55 axle
    Gen 3 Daytona Coyote Gen 3 T56 3.73 diff. (In build)
    Superlite SLC LS3 480 hp Graziano Transaxle
    Aliso Viejo, CA
    Plastic Jig? Not sure what you're referring to.
    Feb 2018
    They are used to center the NRG quick connection to the steering wheel so you can accurately re-drill new holes on the steering wheel to match the pattern of NRG.
    Morgantown, WV
    I have one. I'll have to see if my dad can bring it to me. Won't have it until Sunday at the earliest.
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    If you can't find the jigs (there are two) locally, give me a PM. I have the files if you have a 3d printer. If you don't have a printer I can print them for you.
    Scott Pregont
    My Albums
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    It’s not that hard to mark and drill without the jig. Just take your time and make some accurate measurements.
    Senior Member MSumners's Avatar
    Dec 2018
    Hudsonville, MI
    Have some I can loan if you need.
    Coupe Kit Delivered 11/10/23
    Roadster Build thread: 2019-2022 https://thefactoryfiveforum.com/show...4-Build-Thread
    Feb 2018
    PM sent
