Results 1 to 3 of 3
Thread: Power steering hose connectors
    Member MaxVmo's Avatar
    May 2023
    Hi forum,
    I’m close to first start and need to hook up the power steering. I have the FF power steering rack and a supplied braided hose (which is really long).
    I’m running a BPE 347 and need input on the high pressure and low pressure hoses. The PS reservoir is integrated at the pump with this motor.
    Can someone give me the correct fitting measurements for the high and low pressure connectors for the FF rack? The ones I have don’t seem to fit or I’m doing it wrong, plus the high pressure line is so long—is it worth it to have the line built to a custom length?
    Tips are appreciated as always.
    Thank you!
    Call Mark at Breeze and he will fix you right up. Much, much easier than trying to figure out all those dimensions.
  3. Thanks MaxVmo thanked for this post
    May 2023
    I did not think of that. Thanks for the tip!
