Results 1 to 5 of 5
Thread: Clutch switch set up
    Oct 2022
    Hello!
    While not realizing that I was going to be using an hydraulic clutch initially, I corrected my path as I went along.
    Now, while installing my clutch switch, I see in the illustration (below) a different set-up using the brackets (shown below), that I didn't even realize that I had.
    I can find no instructions for the brackets, or any apparent reason for using them.
    Can I now just put the switch on the existing framework, as indicated in the third photo? Is there a downside to this?
    What am I missing here?
    Senior Member MSumners's Avatar
    Dec 2018
    Hudsonville, MI
    Maybe this. Coyote instructions page 80. Not sure if it’s what you’re thinking.
    Coupe Kit Delivered 11/10/23
    Roadster Build thread: 2019-2022 https://thefactoryfiveforum.com/show...4-Build-Thread
    Oct 2022
    Yes, this is the confusing page.
    There are no build instructions that include the metal plates visible in that illustration.
    I have moved on with the manual assembly and I'm wondering if I can just continue by mounting the switch on the existing 90 degree plate?
    I can't see a structural reason not to, unless I am missing something.
    Mar 2021
    Ohio
    Quote Originally Posted by MSumners View Post
    Is this specific to the Coyote engine?
    Dec 2018
    Hudsonville, MI
    Quote Originally Posted by burchfieldb View Post
    I believe it is.
    The two little metal pieces mentioned were included with my kit. In which box I do not recall.
