Likes Likes:  4
Results 1 to 4 of 4
Thread: DIY Vintage Period Correct Girling Brake Reservoirs
    Aliso Viejo, CA
    This is my second go at making these reservoirs and although there is information out there, a lot of the parts have changed or are unavailable. Here is my write up on this fun little project:
    Parts
    Cans- Basco- $21 for three cans shipped with tax. https://bascousa.com/metal-cans-and-...-in-delta.html
    Girling Lids and Stickers x3 (no longer water transfer) $74 Shipped https://prdcrrct.com/product/girling...v=0b3b97fa6688.
    Actually I just realized you can get better, cheaper stickers here. I didn't notice mine didn't have the white outline. Not sure which is actually correct but I like the white outline better. https://embertonimperial.com/en-us/p...VUMv8OVVQfw44R
    Brass 5/16" Bulkhead fittings (or 1/4" if you prefer) x2 pack $22 https://www.amazon.com/dp/B0CNGPBJLK...sin_title&th=1
    Clamps: made myself for $20 with hardware
    Paint- VHT Epoxy paint- $14
    Acrylic Clear $14
    All in: $155
    Prepping Cans
    Drill it. The metal is thin so best to angle it around a bit to get rid of any flared slag within the hold. This will flatten the hold for a good seat
    Insert Bulkhead fittings with washers. I used some fuel-safe RTV to seal it.
    Tighten those suckers down clean the excess off with Acetone
    Scuff em' with scotch brite pad to get em' roughed up like the one on the left.
    Make up some brackets with some steel strap stock. Drill holes and test fit hardware
    Aliso Viejo, CA
    Next, mask em' up and shoot em' with etching primer for a good hold. Shoot them with the lids on so as not to get the threads of the can.
    Hit the cans and the brackets with the black VHT epoxy paint or any black to be honest...I did a test and it looked like the VHT paint came off pretty quick when exposed to brake fluid. So I tested the Rustoleum Acrylic clear and it helped a lot, it faded a bit but didn't wipe off.
    Put the stickers on first, THEN clear coat them along with the brackets!
  3. Likes rustyrim, Chainsaw liked this post
    The Lengths We Go To In Order To Build Our Dream Cars Is Amazing!
    ...........................The Devil Truly Is In The Details!
    ...................................Bravo, Bravo & Bravo!
  5. Likes ehansen007 liked this post
  6. #4
    Feb 2020
    Virginia
    Erik...
    Thank you for posting this!!
    I found another source for the cans. The cost is about the same as the link you posted but shipping is significantly less.
    https://www.usplastic.com/catalog/it...701&catid=1343
  7. Likes ehansen007 liked this post
