Likes Likes:  10
Results 1 to 9 of 9
Thread: Most difficult job in a Coupe build?
    Jul 2020
    Hi Folks, greetings from across the pond. With a lot of help from a good friend, after several hours grunting and groaning we've managed to get the IRS rear end installed in my coupe - getting the last bolt to go in was a bl**dy nightmare!
    Have I got any more jobs to look forward to that are more difficult than this??
    Dec 2018
    Hudsonville, MI
    I found this to be remarkably difficult on the coupe as well. It was so tight when in place it didnt even need bolts to hold itself up. Way different experience than my initial roadster build.
    Anything can be made difficult with these builds, but I'll say that was the only part to this point that seemed excessively painful.
    Of course.. are you doing bodywork?
    Coupe Kit Delivered 11/10/23
  3. Likes Jphoenix liked this post
    Apr 2020
    Bonney Lake, WA
    No, that's the worst part of it - except for maybe trimming and sanding fiberglass
    Jim Phoenix
    Coupe-R delivered 8/10/2024
    289 USRRC, F5R1011063RD - delivered same day
    Coupe-R has a Ford Performance 363 mated to a TKX, 18084.
    Many details on my Coupe-R are different from a typical Coupe build because mine is not street legal, race only.
    289 has a BP 302 mated to a TKX 18084.
    "For a little more, you can do it yourself." - Ed Hollingsworth... 6-Pack forums
    Jul 2020
    Thanks for your reply - that's good to know! I'm doing bodywork up to a point - hopefully getting the body, doors and hood to fit. Prep and painting will be left to an expert Mind you, I have set myself another challenge - I've invested in a Formacars electric window kit....
  6. Likes Jphoenix, MSumners liked this post
  7. #5
    Jul 2020
    Quote Originally Posted by Jphoenix View Post
    Thanks for your reply Jim - that's comforting . But you're right - I'm not particularly looking forward to trimming and sanding the bodywork...
  8. Likes Jphoenix liked this post
  9. #6
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Getting my hood to fit properly was not the hardest but was the most annoying.
    Scott Pregont
    My Albums
  10. Likes Jphoenix liked this post
  11. #7
    Senior Member TTimmy's Avatar
    Sep 2021
    Emmaus, PA
    I'll second Namrups regarding the hood. I found the process quite frustrating. I felt like I kept chasing around fitment issues from place to place. Eventually it came together.
    I always tell foks to make sure and have some smaller, independent tasks that you can weave into the more complex/frustrating ones. For me I find it nice to be able to walk away from something frustrating but still work on my car, and perhaps have some small accomplishments to re-energize me. Worst case, I just have a couple beers and clean the shop.
    TTIMMY!
  12. Likes Jphoenix, 8secDuster, MSumners liked this post
  13. #8
    Apr 2020
    Bonney Lake, WA
    Yes, fitting the hood is time consuming and very fiddly. I suggest getting it on, then putting the doors on, after locking down the body. Get the doors where they will almost close OK, then get the hood to where it's almost closing OK, then take a step back, sleep on it, have a beer, etc. and then re-adjust the hood mounting hinges so the rod ends are in the middle of their adjustment. I had to re-position the hinges mounting to the hood (re-drill the holes) so only drill one or two holes when you first put the hood hinges on so you can re-position and re-drill. Put the rubber bumpers on, trim a very little bit at a time. Step back, think about it, adjust some more and trim a little bit.
    Takes literally days, but it's not hard, just time consuming and nasty fiberglass.
    Read all the threads like Namrups, EdwardB for tips and tricks and cautions on the hood. My brother-in-law used to do Corvette bodywork and he told me once not to put more body filler on in the morning than you can sand off in the afternoon
    Jim Phoenix
  14. Likes MSumners liked this post
  15. #9
    Senior Member lewma's Avatar
    Jan 2018
    San Diego, CA
    Anything concerning fitting the body/doors/hood was the most time consuming for me. Not hard, just a lot of back and forth.
  16. Likes Jphoenix liked this post
