Results 1 to 4 of 4
Thread: WTB: MK3.1 or MK4 parts
    Jun 2018
    Bettendorf, Iowa
    Good day all!
    I'm working on building an MK3.1 Roadster. I need the following parts if anyone has them, please let me know.
    Todd
    Still needed
    14675 KONI SOLID AXLE REAR COIL OVER KIT
    15414 FRONT UPPER CONTROL ARM WELD-ON RETROFIT KIT
    16285 11.65" SOLID AXLE REAR BRAKES
    17460 ELECTRICAL COMPLETION KIT W/ HARNESS
    14166 2" POWDERCOATED ROLL BAR
    15074 MK4 COMPLETE ASSEMBLY MANUAL (PAPER COPY)
    BRAKE MASTER CYLINDER
    PEDAL ASSEMBLY (CLUTCH & BRAKE)
    Purchased and no longer needed
    12077 SEAT TRACK KIT
    14676 KONI FRONT COIL OVER KIT
    14850 MK4 TWO PIECE SPINDLES
    12066 FRONT LOWER CONTROL ARMS
    Last edited by tnt_motorsports; 02-03-2025 at 04:30 PM. Reason: more updates to the updated list
    Senior Member gbranham's Avatar
    Jul 2021
    Tonganoxie, KS
    I have the rear brake kit (rotors, calipers and pads) for the IRS setup, and the driver's seat track kit. Not sure it'll fit your solid axle setup. You can have all of it, free of charge. Shipping is a bit of a bear. I know this, because I shipped my front set to a forum member a year ago, and shipping was $150. I see you are in Iowa; if you're willing to drive to KC, you can pick it all up, no charge. Otherwise, I'll have to ship to you. The rear calipers I have are painted black.
    Greg
    Build Thread Here Partners: Levy Racing, Summit Racing, LMR, Breeze, Forte's Parts, Speedhut, ReplicaParts
    MkIV Complete Kit Ordered 4/18/23, Delivered 7/11/23, Boss 427W, Edelbrock Pro Flo 4, TKX (.68 5th), IRS, Wilwood Brakes, 18" Halibrands, Toyo R888R Tires, Custom Speedhut Gauges
    Jun 2018
    Bettendorf, Iowa
    PM Sent!
    Jun 2018
    Bettendorf, Iowa
    Bump, I updated list of parts still needed.
