Results 1 to 3 of 3
Thread: Dual intake Gen 4 - M-6007-M50D
    Has anyone pulled the trigger on the dual intake version of the Gen 4? Its what I would really like to use in my coupe just to be different, but I have no clue if it will package. Curious if anyone else has investigated this option? I have seen a few on the forum with the Gen4x, but havent seen anyone with the dual intake version yet.
    For reference its 20 more HP, but 5 less ft lb of torque
    https://performanceparts.ford.com/part/M-6007-M50D
    After putting together a Coupe with a single intake Coyote I can tell you that pretty much all of the real estate in front of the engine gets used up---and even that required some creativity. I think trying to fit in another intake tube and filter would be difficult if not nearly impossible, but I'd be happy to see someone prove otherwise!
    Heart of Dixie, Alabama
    While building my CAI on my Mk IV, Coyote, it seems there was enough gap between the top of the radiator and body to run the cold air intake tube. It would have to be oval. Two tubes over the top, putting the filters in front of the radiator may be an option. I will see, if I can find those old pics.
    good luck,
