Results 1 to 4 of 4
Thread: Donor mustang rear end ratio
    Aug 2021
    Wisconsin
    I just ordered my second FF kit. I built a MKIV roadster in 2023. I ordered a 35' Hot
    rod Truck and I am trying to gather parts. I have a 408 stroker going in it, I am looking for an E4OD transmission and a mustang 8.8 rear end. My question is what would be the best gear for the rear end. I have a 3:55 IN THE MKIV but most of the axles I have spotted are 3:31 or 2:73. Any suggestions ?
    MK4 #10328 - complete kit - Gen 3 Coyote, 6 speed, IRS - ordered 9/9/2021, Built 3/5/2022, Delivered 3/23/2022, Completed build 2/1/2023
    The E4OD has a 2.71 first and .71 fourth gear. These will play well with a 3.31 giving a snappy feel off the line and an overall final drive ratio of 2.35:1 for highway cruising. The 2.73 would be really lazy from a start and way overdriven in fourth with an overall final drive of 1.93:1.
    Aug 2021
    Wisconsin
    Thanks Jeff. I did some math with my wheel and tire choices and came up with the same opinion. Just found and purchased a 8.8 with 3:31 gears.
    May 2018
    Chaska, Minnesota
    I used a 3.00 gears in my '33 and love it. The car is so light, you really don't need deep gears to accelerate , plus the noise level is low due to it running only 1,500 rpm @ 55 mph. It is also a big reason I can get 23-24 mpg on a road trip which is nice with the small fuel capacity we have. (5.3 LS with a 4L65 automatic)
