Thread: Front end spare parts
    Senior Member hdnik's Avatar
    Welland, Ontario Canada
    Quick question for you all.
    I have assembled and mocked up my front end prior to powder coat today. Copied the diagram below and have a few parts left over from the lower arm hardware. First the linkage adjusters had 2 jam nuts on them so in total I had 10 supplied and clearly only needed 8... Should be good there, but I also have 4 very large washers (PN 12387 I believe) that show up no where in the manual for the front end. I haven't started on the rear yet and they may be for there, but wanted to know for sure.
    Thoughts anyone?
    Nick Sebastian - 33 Hot Rod #495
    Factory Five Forums - hdnik
    FFCars - lowntubd
    Build Site/Blog - www.nicks33hotrod.com
    I believe the large washers are spacers in case the lower control arm mounts are too wide.
    Thanks Mike,
    If that's the case then I won't need them. The bushing sleeve assemblies all fit very snuggly. I wonder why no mention of that in the book anywhere?
    FFCars - lowntubd
    Oct 2019
    Erin, Ontario CANADA
    I ended up with the same combination of left over nuts and washers with the addition of 2x 0.25" spacer with internal recess FFR p/n 14406 that end up getting used later at the spindle installation step.
    Earl
    Placitas, NM
    I’m pretty sure the IRS diff uses large washers on the bushings.
    Oct 2019
    Quote Originally Posted by narly1 View Post
    Earl
    I forgot to add that there were two extra plastic pieces (smaller ones in the picture) floating around in the packaging with the (as I recall) upper ball joints. I believe they were meant to protect the ball joints during shipping and will toss them away unless somebody comments otherwise. They don't fit under the bigger boots very well.
    Earl
